Brief Description: Third Coat of Primer on Lower Right WingTop
Completed the first coat of primer on the front half of the bottom of the lower right wing. Installed a drain grommet in the lower left corner near the end of the wing. Completed the second coat of primer on the bottom of the wing bushing the coat on at 90 degree from the first coat. Turned the wing over and sanded the top with the fine sanding foam blocks. Wiped the top of the wing to remove the sanding debris with a shop towel. Rolled and tipped the top of the wing applying the third coat of primer section by section. The bottom of this wing will be sanded during the next work day.
Started sanding the top of the upper right on the trailing edge half of the wing. The leading edge half of the wing will be sanded during the next work day.
