Brief Description: Roll and Tip Primer Painting on Ailerons
Inspected each aileron and ironed down any edges which were not smooth. Rolled on the primer one section at a time followed by "tipping" the area with a paint brush before moving to the next area. Completed painting the four ailerons, the rudder and the vertical stabilizer. Used the soldering iron to melt the center hole in the drain grommets for each of the ailerons. Lightly sanded each of the ailerons, rudder, and vertical stabilizer and set all aside. The horizontal stabilizer is yet to be sanded and painted which will be done during the next work day.
