Brief Description: Start of Sanding of Upper Right Wing
Finished the first coat of primer on the top of the wing on the leading edge half. Applied a second coat of primer to the top of the wing bushing at 90 degrees from the first coat. Turned the wing over so the bottom was up. Used a fine sanding foam block to sand the leading edge half of the wing to smooth the surface, edges, and remove any foam bits left from the painting. The trailing edge half of the wing will be sanded during the next work day.
