LARRY'S WEB SITE
Date:  7-28-2018
Number of Hours:  4.00
Brief Description:  Primer Paint on the Top of the Upper Right Wing
Applied a second coat of primer to the bottom of the upper right wing. Turned the wing over so the top side is up. Ironed the edges of the tapes, around the rivets, and along the end and wing tip to smooth out all wrinkles. Washed the top of the wing, the end, and the aileron cutout with the cleaning solution and rinsed with clear water. Applied a coat of primer to half of the wing that can be reached from the trailing edge. The other half of the wing will be painted during the next work day.
