Brief Description: Primer Painting of the Upper Right Wing Bottom
Sanded the leading edge, wing tip, and the aileron cutout. Ironed the edges, access ports, and around the rivets smoothing down the fabric on the wing. Glued a drain grommet at the trailing edge next to the end of the wing. Used the soldering iron to melt out the center of three of the access ports and the center of the drain grommet. Washed the bottom of the wing and rinsed it with clear water. Applied a coat of primer starting at the end segment after damping the area. Repeated the process around the wing. The next coat will be applied during the next work day.
