Brief Description: Finished Two Coats Primer on Center Wing Section
Completed a second coat of primer on the bottom of the center wing section. Turned the wing over so the top is up. Washed the top of the wing with cleaner and rinsed with clean water. Dampened a section between ribs and painted that area with primer. Repeated the process around the wing including each end and the center cutout. Using the small iron to go over each of the taped edges to smooth them down. Started the second coat of primer by bushing the paint on at a 90 degree direction from the first coat section by section. Completed the painting of the top of the wing section. The sanding will be done during the next work day.
