Brief Description: Initial Sanding of Upper Left Wing
Finished the second coat of primer on the bottom of the wing. Used the small iron to iron down several spots on the tape edges and the end of the wing. Touched up any marks left by the iron with primer. Turned the wing over so the top is up. Using a foam sanding block sanded between the ribs taking care not to sand over the stitch rivets. Completed sanding the top of the wing and then wiped down the wing with a cloth towel. Turned the wing over again so that the bottom is up. Started sanding on the leading edge side of the wing between the ribs. Completed sanding that half of the wing. The trailing edge half of the wing will have to wait for the next work day.
