Brief Description: Two Coats Primer on Top Upper Left Wing
Wiped the top of the upper left wing with a damp rag. Worked each section of the front half of the wing with the spray bottle of cleaner. After applying the cleaner that section of the wing was rinsed with a wet rag. Continued this process around the wing until the entire wing had been washed. Dampen a small section of the front half of the wing and then applied the primer paint with a foam brush going across the wing. Repeated this process section by section until the complete wing was painted. Started back at the beginning of the painting process, applied a second coat of primer this time brushing along the wing one section at a time. Continued this pattern until the complete wing was painted. End of day.
