Brief Description: Second Coat of Paint on Inside Wheel Covers
Evaluated the primer on the inside wheel covers and found that it was not adhering well to the aluminum. Still going to see if additional coats and cure time will make a difference. Sanded the wheel covers with 1200 grit sand paper. Wiped the inside covers with paper towels to remove the sanding dust. Applied a second coat of primer to both sides of the inside wheel covers. Set them aside to dry.
Sanded the bottom side of the belly pan with 1200 grit sand paper. Applied a second coat of primer to the inside of the belly pan. The bottom will be painted following the evaluation or the current primer paint.
