Brief Description: Installed the Repaired AOA Display
Connected the wiring plug to the back of the display and control box and tighten the retaining screws on the plug. Mounted the display behind the instrument panel and positioned the display over the opening and secured it with three #8 by 1/2 inch allen screws. Plugged in the setup box on the back of the control box. Powered up the unit and observed the self checking display. Attempted to perform a system reset function per the instructions in the manual. The display changed but the indications described in the manual did not occur. Also was not able to get an indication that the indicator pot was connected to the control box. Will review the manual and try again during the next work day.
