Brief Description: Completed the Air Tubes for A/S and Static
Replaced the 1/8 NPT 90 in the air speed indicator with a 1/8 NPT by 1/4 OD shark-bite coupling to accept the tubing straight out from the back and up to the center wing section. Installed the remaining two short segments of 5/16 OD by 3/16 ID tubing for the static air pressure on the T's for the altimeter, VSI, and airspeed indicators. Connected a long segment of the 5/16 OD tubing from the airspeed indicator up to the center wing section and out the left side.
Measured off the 4-wire from the AOA display out through the center wing section and cut to length. Installed the female end of a 4 wire plug on the AOA indicator wire. Soldered the ground shield to the right lug from the alignment grove on the plug looking on the face of the plug.
Checked out the left outer wing struts and marked the front strut where the AOA vane is to be installed 12 inches under the bottom of the wing. Brought the struts home to get them painted.
