LARRY'S WEB SITE
Date:  9-9-2019
Number of Hours:  1.00
Brief Description:  Found and Repaired the Bad Connection on the Temp
Used a pair of stick pins to check out the leads on the temperature probe for connectivity. Found that the red wire was not connected through to the prob. Removed the probe from the side panel and slid the splices through to the outside. Removed the cover on the splice for the red wire and reset the wire in the splice and crimped it. Checked the temperature reading on the display and found it correct. Carefully inserted the wires back through the side panel along with the prob. Slid the lock washer and tap down on the probe and tighten on the side panel. Slid the heat-shrink tubing down over the splices and the threaded end of the prob. Checked the reading again and found it correct.
