Brief Description: Continued Work on AOA Wiring Harness
Selected a location for the AOA circuit breaker on the left side of the carb heat display. Used a step bit and drilled a hole for the breaker. Plugged the wiring harness into the AOA display and measured the length of the power wire necessary to reach of the circuit breaker. Also measured the length of the power wire needed to connect to the avionics master switch. Cut the red power wire at the marked location and installed a crimp terminal. Placed a 5/8 inch length of heat-shrink tubing over the terminal and set it in place with a heat gun. Cut a length of 22 gage red wire for the connection from the breaker to the master switch. Installed crimp terminals on each end and cover each with a length of heat-shrink tuning set with the heat gun. Mounted the red power wire from the AOA plug to the circuit breaker. Mounted one end of the red power wire for the master switch to the circuit breaker. Removed the avionics master switch from the instrument panel. Removed the wire going to the avionics terminal block and reinstalled it along with the power wire to the AOA circuit breaker. Reinstalled the avionics master switch back into the instrument panel. Still have the dimmer pot to install and connect the ground wires. Ordered a knob for the dimmer pot to be installed when it comes in.
