Brief Description: Evaluate Location for AOA Installation
Installed a 1/4 by 2 1/2 inch bolt through the end of the tail wheel shaft by securing the bolt with a self locking nut on the end and a second nut on the shalf. Tighten the second nut up against the shalf and applied medimum lock-tight to secure it in place. This should provide a stop to keep the bungee cord from sliping off the end of the shaft.
The choosen position for the AOA display is on the lift side of the insturment panel next to the altimeter. Checked the location to ensure that the display would clear the cover for the instrument panel. Removed the back of the display to serve as a template for marking the instrument panel mounting holes for the display. Found that the ethernet port was installed on the left side next to the wiring plug for the display. The back plate will have to be modified to allow access to this plug during the set-up of the system. Used the template to mark the top left hole for the display mount. Drilled the marked location with a 3/32 inch drill and placed the template in place with one of the mounting screws in the newly drilled mounting hole. Carefully aligned the template and drilled the top right mounting hole. Place a second mounting screw in the hole and then drilled the two bottom holes through the instrument panel. The opening in the instrument panel for the display LEDs will be cut during the next work day.
