Brief Description: Finished the Power and Ground Wires On Transponder
Measured the power wires necessary to reach the circuit breaker and cut away the excess. Removed the instillation from the ends of each of the red wires and wrapped them together. Rubbed on flux and tinned the end. Installed two wire labels on the power wires and added a 1 inch segment of heat-shrink on the wires. Crimped a terminal on the power wires and then slid the heat-shrink tube down on the terminal. Measured out the length of 20 gage red wire needed to connect the circuit breaker to aircraft power. Printed a label for the power wire and slid it into place. Installed a length of clear cable protection to the data and power wires between the cable ends. Added a length of yellow cable protection to the four ground wires.. Cut away the excess cables to reach the ground buss. The transponder is not ready to be installed into the instrument panel.
