Measured the existing wiring harness from the blind altimeter and cut the data wires at the designated length. Installed terminals on all of the data wires with the crimping tool for these terminals. Laid out a written diagram on which wires go to which ports on the transponder plug. Matched the color wire to the specific port in the order of ports from B to M. The power, ground and control wires are yet to be installed.
