Brief Description: Continued Testing The Radio Wiring Harness
Installed a mini push-button on which two wires were connect to the right throttle handle. Plugged the radio harness into the back of the radio and laid out the wires to the sides of the instrument panel. Plugged the left intercom push-to-talk cable into the radio wiring plug. Connected the intercom hot switch into the intercom wire. Plugged the right intercom push button into the wiring harness. Mounted the left headphone and MIC plugs into the instrument panel on the lower left edge. Mounted the right headphone and MIC plugs into the instrument panel on the lower right edge. Connected the backlight dimmer switch and rheostat circuit to the wiring harness. Connected the music input plug into the wiring harness. Connected the power wires to the circuit breaker and mounted it into the instrument panel. Mounted the other end of the power wire to the avionics part of the power buss on the instrument panel. Mounted the ground wires to the ground buss on the instrument panel.
Powered up the radio and checked out the functions. Initially found no output on the headphone jacks. Rechecked the wires terminated on the jack and found that they were connected to the wrong terminals. Corrected the terminations and could hear noise on the headphones. Checked each of the push-to-talk switches and all appeared to work. Checked the functions of the radio and all seems to work correctly. Still have to check out the reception and transmission.
