Brief Description: Continued Working on VHF Radio Plug
Applied rubber cement to the top edge of the instrument panel to glue the veneer to the metal back plane.
Continued work on the intercom push-to-talk circuit by installing two wire plugs on each leg of the circuit. This provides connections for the pilot and copilot's push-to-talk buttons on the throttle quadrants.
Reviewed the circuit for the backlight dimmer for the radio. Spent some time in the cockpit looking at locations for the 50K rheostat and SPDT switch. Decided on mounting the switch and rheostat on the lower right side of the radio. Drilled a hole for the switch and also one for the rheostat. Completed wiring up the circuit at the work bench and installed a two wire plug. Installed a two wire plug on the radio dimmer wire with the second wire being a ground wire. Connected the other end of the ground to the ground wire at the plug to complete the dimmer circuit.
