Brief Description: Replaced the Transponder Antenna Cable End With A
Cut off the TNC connector from the end of the transponder antenna cable which was provided in error on the cable order. Used the cable stripper to remove the layers for the installation of the BNC connector. Slid the wire end into the center pin for the connector and crimped it in place. Placed the BNC collar on the antenna cable. Slid the center pin into the BNC connector and pushed the connector under the shield of the cable. Slid the collar up over the shield wiring and against the connector. Crimped the collar onto the connector to complete the installation.
