Brief Description: Installed the Transponder Antenna on the Belly Pan
Put seven of the brass washers on the right wheel outer axle. Put the remaining three brass washers on the left outer axle.
Wiped down the sanded areas on the belly pan with MEK. Placed the antenna back plate on the mount area and secured in place with two cleos. Installed two 1/8 pop rivets into the back plate. Removed the cleos and installed two more pop rivets. Slid the antenna in place and secured it with the lock washers and nuts provided.
Evaluated the stick area for the addition of a wiring tube from the stick to the back of the instrument panel. Will need about 5 feet of 3/16 inch tubing to make the connection.
