Brief Description: Finished Labeling the Instrument Panel
Created labels for the remaining circuit breakers, fuel primer, mixture, oil accumulator, oil temp gage, carb heat, and master power switch. Cut and install each of the labels at their appropriate location. Install two 1032 pan head bolts into the instrument panel on the lower corners securing the instrument panel to the sides of the fuselage.
