Brief Description: Installed the Antenna Lead in the Transponder Case
Prepared the end of the cable by removing 1/2 inch of the outer shell. Then removed 1/4 inch of the shield and then 1/8 inch from the end exposing the lead wire. Applied flux to the lead end and the end of the lead in the case adapter. Tinned each lead. Slid the antenna cable into the opening on the side of the case adapter and positioned the lead next to the adapter lead. Applied the soldering iron to the junction of the leads and completed the connection. Applied flux to the cable shield and soldered the shield to the case adapter. Installed the ferret plug in the case adapter and placed the cap on the end. Applied solder to two points on the cap to secure it to the case adapter.
Placed the case adapter into the case and secured it with the snap ring into the case.
