Brief Description: Cable Penetrations of Fabric Locations
Cable penetrations of fabric locations
Left Wing Aileron Top cable; 1” left of wing rib 9 ½” to 10 ¼” from aft wing edge. Bottom cable; 1 1/8” left of wing rib 18 ¼” to 19” from aft wing edge.
Right Wing Aileron Top cable; 3/8” left of wing rib 8 ½” to 9 ¼” from aft wing edge. Bottom cable; ¾” left of wing rib 18 ¾” to 19 ½” from aft wing edge.
Fuselage Right Side Top Cable; ¼” down and 45” from aft elevator attachment tab back edge. Bottom Cable; 9 5/8” down and 44 ¼ “from aft tail post outside.
Fuselage Left Side Top cable; ¼” down and 39 ¾” from aft elevator attachment tab back edge. Bottom cable; 10 3/8” down and 44 ¼” from aft tail post outside.
Fuselage Bottom Left cable; 5 3/8” from left side 23” from tail post outside. Right cable; 5 3/8” from right side 23” from tail post outside.
Fuselage Top Right cable; 6 ½” from right side 22” from tail post outside. Left cable; 5 3/8” from left side 22” from tail post outside.
Elevator Left Side Top fabric; 6 ¼” from inside rib and 7 ¾” from front edge. Bottom fabric; 4 ½” from front edge and 4 “ from inside rib.
Elevator Center Section Left Side Top fabric; 2 “ from left rib and 9” from aft cross pipe. Bottom fabric; 4” from left rib and 14” from leading edge.
Elevator Center Section Right Side Top fabric; 7 ¼” from aft pipe 2” from right rib center. Bottom fabric; 4” from right rib and 12” from aft pipe.
Elevator Right Side Top fabric; 16 ¾” from aft pipe and 8 ½” from left rib. Bottom fabric; 2 ½” from front edge and 4 ¼” from left rib.
