Received a new continuous duty 12V solenoid today just after lunch. Mounted the new solenoid to the firewall and connected the two main fuses to each side of the solenoid. Constructed a new 10 gauge power lead and connected it to the activation terminal of the solenoid. Connected the ground lead from the keyed switch to the second activation terminal of the solenoid. Completed the installation by connecting the main power lead from the battery to the left side of the solenoid. Installed the battery back into it location on the airframe and bolted the top frame down on the battery. Connected the power lead to the battery using a washer and lock washer and nut. Connected the three ground leads to the battery to complete the connection.
