LARRY'S WEB SITE
Date:  7-4-2019
Number of Hours:  3.70
Brief Description:  Installed Intercom PTT/Hot Switch
Placed the IPad Mini into the holder in the center of the instrument panel to determine if it fits. The fit was good and the holder will allow the addition of a case to protect the IPad. The addition of a power cord will complete the installation of the IPad.
Evaluated the requirements for the intercom connections. Added a SPST switch below the radio to the right which will be used to set the circuit from push-to-talk (PTT) to hot MIC. Installed a two wire female plug on the end of the switch wires. On the radio wiring harness connected two additional wires to the intercom wire and crimped a male terminal on the wires. Installed a ground wire plus two additional ground wires on the second male terminal. Mounted the terminals into the case. The extra wires will be terminated in two wire plugs and connect to the PTT switches on each of the throttles.
Installed a #6 screw into each of the handle sleeves on the yoke to hold them in place. Mounted the yoke on the stick by connecting the PTT wire plug and sliding the wires down into the stick. Aligned the holes and installed a blind bolt through the yoke and stick.
Intercom Switch and IPad Mini
Secured Yoke Handles
