Brief Description: Worked on Organization of Instrument Panel Wiring
Installed a standoff zip tie on the tail light wiring near the plug. Added standoff zip ties to the engine ignition wire bundles to better secure from vibrations. Gathered up the firewall wire bundle on the left side and secured it to the fuselage with a standoff zip tie and a zip tie on the wire bundle itself. Repeated the bundling of the firewall wires in the center of the fuselage and secured with a standoff zip tie and bundle tie. The red wire for the oil pressure warning light came up too short and will have to be replaced. Continued to add standoff and other zip ties to secure and route the wiring clear of hazards. More work to do in this area.
