Brief Description: Connected Main Ground and Ignition Power
Connected the main power buss to the primary ignition diode with a 12 gage red jumper labeled IGN PWR. Completed the connection from the scavenger pump switch to the firewall terminal for the oil scavenger pump. Removed the jumper from the instrument light switch to the cockpit light switch and replaced it with a connection from the cockpit light switch to the landing lights circuit breaker. Installed a 14 gage red jumper from the main power buss to the alternator power circuit breaker. Installed a 12 gage black jumper from the main ground buss to the instrument panel grounding terminal.
