Obtained a 1 1/2 inch #10 self taping screw and drilled the lower connection point on the outer edge of the wing stub step. Installed a 1 1/4 inch #10 pan head screw to pull to outer edge of the step down inline with the outer edge of the wing stub. Removed the front self taping screw and replaced it with a #10 pan head screw to pull the front outer edge of the step inline with the wing stub.
Completed the starter solenoid circuit by connecting the switch to the power distribution buss with a 12 gage red wire. Build the eight inch 12 gage red wire with terminals on each end and labeled at each terminal end with ING PWR. To be installed during the next working day.
