LARRY'S WEB SITE
Date:  1-6-2019
Number of Hours:  3.00
Brief Description:  Continuing Connecting Engine Instruments
Completed the EGT sensor wiring by measuring the length of the supplied cable and cutting to size. Installed two female blade crimp terminals in the cut end and connected both ends. Printed three flag labels marked EGT PROB and applied to the cable at each end and in the middle. Completed the sensor wiring for the oil pressure and temp applying labels to each. Connected the TAC sensor to the left ignition lead and the display. Also completed a wire from the battery to the TAC display.
