Brief Description: Installed Cockpit and Instrument Light Switches
Marked the position for the SPSD switch on the back of the instrument panel. Used a 1/2 inch step-drill to form the opening for the instrument panel light switch. Installed the power wires to the switch and labeled each wire. Added a control knob to the instrument light rheostat. Installed power wires on the instrument light controllers. Realized that the cockpit lights needed a switch to control the power to the controller so moved the isolated power supply for the amp display and drilled a hole and installed a switch. Ran the power from the instrument light switch to the cockpit switch. Build a power wire from the cockpit switch to the power entry points for the landing and position light switches.
