Brief Description: Mounted Terminal Blocks on Instrument Panel
Positioned the power terminal block and pilot drilled the right side of the block. Placed a pin in the right side and pilot drilled the left side. Used a countersink bit and drilled the front of the panel to accept an 8 by 1/2 inch flat head screw in each of the holes. Mounted the block with two #8 brass screws and nuts. Repeated the above process for the ground terminal block directly above the power terminal.
Completed the ground wire for the right side instruments and mounted it to the ground terminal block. Added a label on the ground wire at both ends. Installed labels on the power wires for the lift side ignition and the fuel pump. Build a power wire from the rheostat to the power block with three labels. Installed a instrument light power wire from the voltage indicator light to the power terminal block instrument light area including labels. End of day.
