Brief Description: Installed Rheostat for Instruments Lights
Run a red 16 gage wire from the instrument circuit breaker to the voltage meter. Connected an 18 gage red wire to the USB module + terminal. Also connected the red power wire from the amp display all tied in at the + terminal of the voltage meter. Also ran a 16 gage wire to the instrument terminal block for power to those additional connections. Connected an 18 gage black ground wire from the USB terminal to the instrument light also picking up the ground wire from the amp display and the ground terminal from the voltage gage and completing the connecting to the ground terminal block.
Drilled a hole on the line above the light switches and installed the instrument light 50 ohm rheostat.
