Mounted the second half of the ground buss bar centered on the firewall under the engine wiring pass-through. Mounted the ground wire from the left side engine wiring bundle to the left terminal on the ground buss. Installed a crimp terminal on one end of the CHT wiring pair. Mounted this to the left termination point on the buss bar on top of the engine ground. Measured the length of the 12 gage black wire from the lower ground buss and cut to fit the right center termination point. Installed a crimp terminal on the ground wire and mounted it to the upper ground buss on the right of center terminal. Installed the right engine grounding wire to the right side terminal on the ground buss.
Installed the engine terminal block on the firewall to the left of center using two 3/16 inch pop rivets. Starting at the bottom, mounted the left and right engine ignition wires. Mounted the EGT probe wiring on the next two terminals. Installed a crimp terminal on the black 12 gage wire from the starter solenoid and mounted it to the terminal block. Installed crimp terminals on the electric fuel and scavenge pumps and mounted them on the next two terminals. Installed crimp terminals on the two black wires coming from the alternator and mounted them on the next two terminals. Put crimp terminals on the red and black wires from the oil block pressure sensor and warning light sensor. The last wire for the top terminal is the CHT wire which has a crimp terminal installed and terminated on the top terminal block mount.
