Cut the duel buss bar in half leaving two mounting holes on each half. Mounted the buss bar on the firewall near the center just above the lower cross member using two screws. Mounted the grounding wires from the electric fuel pump and the scavenge pump to the buss bar. Measured a length of 12 gage black wire from the battery terminal to the left side of the buss bar. Mounted terminals to each end of the 12 gage wire ensuring correct size to fit each mounting location. Doubled checked each crimp for correct application. Mounted the ground wire to the buss bar. Measured a length of 12 gage black wire from the lower buss bar to the top of the firewall. Installed a crimp terminal on one end and mounted it to the right side of the buss bar.
