Brief Description: Wiring for the Electric Fuel Pump
Measured out a length of black 16 gage wire for the ground side of the connection. Put terminals on each end ensuring that the crimps are complete and tight. Secured one end of the black wire to the left center terminal and the other end at the lower ground block. Measured out a length of red 16 gage wire running from the terminal strip to the top of the firewall. Put a crimp terminal on one end of the red wire and mounted it to the right center terminal block connection. Again doubled checked the crimp on the terminal for security.
