Brief Description: Cable Clamps and Alternator Wiring
Cut out an aluminum clamp to fit on the fuselage diagonal and drilled it for a 1032 screw. Connected the clamp to the right side of the fuselage and mounted a cable clamp to hold the power cables in place. Secured the power cables to each other about every 6 inches from each other or support clamps.
Put blade terminals on two segments of 18 gage wiring and connected them to the alternator. The other ends will be secured at the firewall terminal strip.
