Brief Description: Initial Electric Wiring Design Efforts
Checked the firewall fittings on hand and tried to fit the engine ignition wiring through the fitting, It didn't fit so a larger diameter fitting will be required.
Looked at possible position for the main solenoid near the battery box. Nother settled yet, Put appropriate ends on a short segment of 12 gage wire and connected it to the solenoid.
