Brief Description: Installed Spacers on Brake Calipers
Removed the two 3/8 by 1/2 inch bolts which hold the caliper to the right axle frame. Installed two aluminum washers on each of the 3/8 by 3/4 inch bolts to secure the caliper back on the axle. The resulting offset centers the stator in the center of the caliper gap. Repeated the process for the left side brake.
Checked out the possible mounting options for the landing light on the right wing stub. More checking will be required to complete a design.
Replaced the connecting bolts on the throttles with AN3 bolts with cotter pin nuts to complete the items on the construction inspection punch list.
