Brief Description: Installed the Covering on the Work Tent
The covering is draped over the frame starting with the back end of the tent. A strap is run through the edge of the end piece and pulled tight at the bottom with ratchets securing the covering to the frame. The same process is used for the front of the tent. The sides and top are one piece and pulled over the frame with ropes attached to each end of the covering. The top and sides are secured to the frame at each end with straps through the covering and secured at the bottom of each end of the frame. One side of the front is zipped open as an entrance. A propane heater is added to provide a heated work space.
