LARRY'S WEB SITE
Date:  11-15-2019
Number of Hours:  0.50
Brief Description:  Oil Site Gage Vent
Removed the top of the clear tube of the oil site gage from the oil tank. Pressed the nylon plug up out of the tube and drilled a 1/16 inch hole in the center of the plug. Installed the plug back into the site gage and put the tube back onto the oil tank. Moved the spring clips in place to keep the tube on the fitting and the plug in place at the top of the tube.
Installed a wire tie on the group of electric wires that were routed near the top of the oil tank. This was to move the ground cable away from the gas tank fitting and secure the wiring from vibrations.
