Brief Description: Setup Oil Accumulator Head Pressure
Reviewed engine oil requirements and checked on availability. Will have to order from the internet.
Reviewed the operational instructions for the oil accumulator. Tighten the pressure relieve value on the accumulator. Reduced the head pressure to about 15 psi for operational use. Will need to reduce to about 10 psi for proper operation.
Discovered that the master key can be removed from the switch at any time even when the power is turned on. May need a fix for that.
