LARRY'S WEB SITE
Date:  5-1-2017
Number of Hours:  4.00
Brief Description:  Installing the Oil Accumulator
Mounted the oil accumulator on the engine mount on the top left side using two steel clamps. Care was taken to ensure the pressure gage and control value arm was oriented correctly. Measured and marked the steel covered AN6 hose from the accumulator to the bottom of the oil filter block. Installed an AN6 fitting on one end of the hole and a 90 degree fitting on the other end. Installed one end on the accumulator and the other end to the tee at the bottom of the oil filter block.
Measured the line from the filter block to the output of the engine driven oil pump and cut to length. Install a straight AN6 fitting on one end and a 90 degree fitting on the other. Mounted the straight fitting to the 90 degree elbow on the oil filter block.
Oil Accumulator Mounted Top Left
Oil Line Installation
