Brief Description: Throttle and Mixture Cable Clamps
Added a clamp set to the throttle cable attaching it to the fuselage cross member behind the firewall. Set the alignment to support a smooth transition to the instrument panel. Checked the routing of the mixture cable and adjusted it to a loop on the left side of the fuselage. Fabricated a aluminum clamp for the fuselage and attached it to a cable clamp on the mixture control cable. Set the alignment to clear the rudder bar and provide a smooth transition to the instrument panel.
