Brief Description: Painting the lower frame of the instrument pannel
Cleaned the bottom rail of the instrument panel using MEK. Mixed the can of self-etching primary and sprayed on one coat. Let it dry for 15 min minimum and checked fit and finish. Applied a second coat of the primer to the front side.
