Brief Description: Installing Clamps to Protect the Oil Lines
Checked the oil lines and cable paths and identified several locations where clamps were needed to maintain clearance on the surrounding areas. Rerouted the oil line from the engine oil pump to the filter block for better clearance. Installed a set of clamps around the grounding cables tying the electrical to the aircraft systems. More clamps are waiting to be installed just waiting on nuts.
