Brief Description: Throttle Cable Through the Firewall
Installed the throttle firewall access by drilling a 7/8 inch hole in the firewall. Created two aluminum washers to be installed with the pass-through fitting. Mounted the pass-through fitting using the two washers and the nut provided. Added blue lock-tight and tighten the fitting nut snug against the firewall.
Routed the throttle cable through the firewall fitting taking care to maintain the proper clearance. Double checked the alignment of the cable and then tighten the pass-though fitting holding the cable in place.
