Brief Description: Installed the Mixture Control Cable Firewall Pass-
Evaluated the proper location for the mixture cable to come through the firewall. Drilled a 3/4 inch hole in the firewall at the selected location to accept the pass-through fitting. Cut two aluminum washers to fit over the pass-through fitting. Installed the pass-through in the opening using the two aluminum washers and secured it with blue lock-tight.
