Brief Description: Firewall Pass Through and Engine Electronics
Installed the cable pass through on the firewall for the Engine Primer Cable. Next mounted the electronic module for the right engine distributor. Positioned the module and drilled the hole for a number 8 screw. Mounted the module on the existing hole and then drilled the second hole. Covered the back of the module with heat transfer grease that was provided with the module. Mounted the module to the firewall with two #8 screws and locking nuts. Repeated the process for the left module.
