Located positions for each of the coils on the upper engine mount arms. Marked each location and measured two 1/2 by 1/8 inch steel straps the length of the coil. Cut each mount and ground the edges to shape. Clamp each mount in position using vice-grips and spot welded it in place. Removed the vice-grips and completed the welding of each mount. Cleaned up each weld with a finish grinding wheel. Painted each area with black paint taking care to not over spray into other areas.
