Brief Description: Installing Oil Lines Behind the Firewall
Installed an AN6 hose barb on to a 3/8 inch ID hose end. Installed a hose clamp on the AN6 hose barb. Connected the AN6 fitting to the firewall fitting for the oil return. Cut the hose at about 2 inches and installed a check valve with hose clamp to prevent backflow. Installed another 2 inch segment of hose with clamps and included a 3/8 inch brass T. Connected a final segment of hose from the T to the oil return port on the oil tank using an AN6 hose barb and clamps.
Measured the length of 3/8 inch hose necessary to connect the output of the electric scavenge pump to the brass T in the oil return line. Cut the hose to length and installed using hose clamps between the scavenge pump and brass T.
Installed an AN6 90 deg hose barb on one end of a segment of 3/8 inch hose with a spring clip. Connected this end to the AN6 male fitting on the oil tank output. Measured the length of hose necessary to reach the oil input fitting on the firewall. Cut the hose to length and installed it on the oil input hose barb at the firewall using a spring clip.
